Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Installing A 90 Amp Fuse
  • Installing A 90 Amp Fuse
    The 90 amp fuse on the starter of my Mercruiser 5.0 needs to be replaced (my screw up ). Due to the configuration of my boat (Nautic Star 232 DC), this fuse is EXTREMELY hard to get to. Has anyone heard of installing this fuse remote? As in adding a short jumper wire (4 gauge) from the post on the starter to the fuse? I don't like the fact that if this fuse were to blow while away from shore, there is really no way to temporarily bypass the fuse to get home. Any help would be greatly appreciated.
    Thanks.
    2008 NauticStar 232DC I/O
    5.0TKS Mercruiser / Alpha Outdrive
    Re: Installing A 90 Amp Fuse
    Originally posted by plumbbob5000 View Post
    (my screw up )
    All things being equal, the chances of the fuse blowing are remote.
    From Mercruiser:
    Anyone who uses a service procedure and/or tool, which is not recommended by the manufacturer, first must completely satisfy himself that neither his nor the product’s safety will be endangered by the service procedure selected.
    • #3
      Ayuh,....
      Either put it back Exactly where it Belongs,....
      Or,..
      If it was My boat,... I'd just Toss it,+ hook the wire directly to the starter, like it's been done for the last 50 Years....
      Those big Fuses are a New Safety feature that some Lawyer decided needed to be there.....
      • #4
        You must have seen the wiring pictures posted.
        How much do you want to bet, he hacks the wiring to just eliminate the fuse!
        From Mercruiser:
        • #5
          That "screw up" that blew the fuse to begin with, didn't destroy anything else when you shorted it, because that fuse was there, not a few inches away. When you short it again down there and the fuse is farther away, you will melt something.
          Don S.
          Please, no PM's (Private Messages) regarding boat/engine problems.
          That is what the forums are for.
          Only forum/moderator issues will be answered in PM's.
          • #6
            Thanks to everyone for your suggestions. I decided to go ahead and install the new fuse exactly where I found the old one. I'll just be sure to buy a brighter flashlight so that the next time I'm catfishing at night and my battery dies, I can actually see the trolling motor battery good enough to jump it correctly. Thanks again. I'm sure I'll be needing your help again one day. Hopefully not too soon though!
            • #7
              When this fuse blows what happen to the boat? Does start? Doesn't charge?
