holgo123
- Jun 12, 2006
- 89
1993 OMC Cobra Ford 5.0 l EFI/MPI ~ I am re-installing the sender units, oil pressure, oil pressure warning, and water temperature on a replacement engine. I found instructions on the water temperature to not put any teflon tape upon installation. I found mixed instructions on the oil pressure senders. Some say to not use tape others say to use yellow teflon tape. Don't the threads need to be bare to make contact with the block for grounding purposes? Thanks!
