Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
4.3L V6 Mercruiser Stern Drive...HELP!
  • 4.3L V6 Mercruiser Stern Drive...HELP!
    Hi,
    Changed the main wiring harness on my mercruiser and have power to the circuit breaker, but nothing coming out of it. Could it be a bad breaker? Is there a way to test it? I think I have everything wired correctly??
    Re: 4.3L V6 Mercruiser Stern Drive...HELP!
    Year? Model? EFI, Carbed, Drive, lots of different harness options.
    Yes, it could be the breaker.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      1993 Sea Ray 4.3L V6 Mercruiser
      Carbed - yes
      don't know what your other questions mean?
      • #4
        Is there a way to test the breaker?
        • #5
          Disconnect the red/purple wire from the breaker. push the reset button. If there is no power to the empty terminal, then the breaker is bad.
          Don S.
          • #6
            Thanks Don - followed your steps and we have power to the empty terminal. Tried again to reconnect and test, seems to be grounding out somewhere? Any suggestions? Also, no power to the electrical panal at front of boat??
            • #7
              Sounds like you have a short that is popping your breaker.
              Disconnect the main harness plug (the round one) on your engine and see if it still pops the breaker.
              Don S.
              • #8
                Yes - still pops the breaker
                • #9
                  You may have a short in your wiring harness on the engine. Have any work or repairs been done to the engine lately, and I mean any repairs?
                  Don S.
                  • #10
                    Changed the main wiring harness on my mercruiser. Yes - still pops the breaker
                    Ayuh,....
                    In that case,.... You Screwed Up the installation of the New Harness.....
                    Now,...
                    You've can only go thru it,+ Find the screw up......
                    • #11
                      How the ............. did I miss that.
                      Duh
                      Like Bondo said, you have it installed wrong.
                      Don S.
                      • #12
                        BINGO!
                        Thanks for your support and advise. Had the alternator wires swapped. Changed them, and works like a charm! (knock on wood! the real test will be this weekend)
                        • #13
                          Who is this fake Bondo that was correct?
