gamarines2
- Jun 14, 2007
- 102
Year two of my restoration after boat sinking......
Power steering on my 21'6" Glastron with 350 Mag Alpha 1 was really stiff this year. My first inclination was that the contaminated hydraulic fluid in the system killed the pump, so I replaced it....no joy.
I read some of Don's advice and thought it was the steering cable. Tonight, I disconnected the cable and the wheel still turned stiffly, but not as stiffly as when connected, which makes sense. I think the wheel should turn effortlessly with the cable disconnected on the business end, so I ordered a replacement cable.
But I did another troubleshooting experiment while I had the cable disconnected, and that was to move the steering lever by hand with the engine off (not power assisted) and then with it running (power assisted). I could move that lever with some resistance but the level of effort didn't change with the motor running or not.
So, I am assuming that when I get my bright, shiny new cable installed, I will still be using both hands to dock my baby in its berth.....
What should be my next test/repair/replace option?
Jake
Jake
