Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Alpha 1 outdrive won't lift, no motor sound; Help-PLease
  • Alpha 1 outdrive won't lift, no motor sound; Help-PLease
    Started up the boat "93" after being dormant for two years, the fluid in the outdrive was not milky but was black. Unfortunately I could not even get the motor to make a noise when trying to lift the outdrive. Any suggestions on what to look for.
    Thx
    Sean
    Re: Alpha 1 outdrive won't lift, no motor sound; Help-PLease
    There's a seperate slave solenoid for the T&T motor, probably corroded connections on it, or it's gone bad,,, find it, & clean, & lube all the terminals, then try again. On boats there are a lot of extra solenoids to check.
    By the way, Welcome to the forum
    • #3
      Go the the link below. Strarting on page 12 is detailed troubleshooting steps for testing the trim system, including wiring diagrams.
      http://www.boatfix.com/merc/Servmanl/14/14c1.pdf
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Thank You both very much. I will try the recommendations and respond back.
        Sean
