I recently purchased a sterncraft 1973 with a 120 hp mercruiser by gm I believe it had been sitting for about 4 years and the last time it was used it was in the water overnight and the back end filled up with water up to the starter. I changed the oil and it was milky so after I put new filter and oil I hooked up the ear muffs to it and have run the engine for atleast a half hour and no milky oil has returned. I also checked all the cylinders for water and corrosion and found none. It starts right up and runs good I was told it had been properly winterized after last use and I believe the guy. Could this be condensation buildup from sitting for so long or could there be another problem from when it was in the water or something else
any adviced would be appreciated.
