last spring I pulled my 79 crestliner with a 165 mercruiser I/O out of the garage and discovered water in the oil? The oil looked like cappuccino. To investigate I took the head, exhaust manifold and oil pan off to look for cracks and found nothing. The only thing I discovered was a bad manifold gasket. Could this be the problem? I purchased a gasket kit and am now in the process of reassembling the engine. Does anyone have the torque specs for the head, and rocker arms (especially the rocker arms) . I was told that the head torques to 84 pounds. Is this right?
Also the boat was winterized well, had four gallons of antifreeze in it over the winter but it looked to me like the manifold was frost wedged away from the block, weird!!!!
