Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Manifold removal 3.0 mercruiser??
  • Manifold removal 3.0 mercruiser??
    I am the not so proud owner of a 1997 Bayliner Capri 1950. I think I have a cracked block, but I need to remove the manifold to see the problem. This is a 3.0 mercruiser motor. I don't want to just start taking bolts out blindly. Does anyone no where I can get a good manual that shows how to do this the correct way? OR does anyone here have any advice on removal or pictures??
    Thanks
    Re: Manifold removal 3.0 mercruiser??
    e-Bay search is one. Order manual from your local Merc dealer is another. Stay away from the Clymer, Seloc manuals. Stick with OEM stuff. Failed to mention if it was your intake or exhaust you were needing to remove. Either way bolt removal is not an issue - replacing them to the correct torque sequence is. So have at it - but find that manual for replacement.
    Life may not be the party we hoped for, but while we are here we might as well dance
    • #3
      Damn, I ordered a Seloc manual before I got back here to check for responses.....
      • #4
        Ok, I got that order canceled and I am ordering an OEM service manual. I will let you know when I get started. I am getting water I thought from the side of the block, but I went home and took a picture and it appears like it is coming from under the exhaust manifold. I want know until I tear it down next week. I am going to post pics step by step in case someone else runs into this problem down the road. Wish me luck! I am mechanically inclined, but never worked on a boat motor before.
        • #5
          Boat motor, car motor - basically the same critter. There are several differences in the guts but nothing really strange. Starter, alternator - all spark proof. Carb cover wire mesh or grill, never paper, and so on.
          Does the water appear when the motor is running? A loose or cracked hose close by? Sorry, just throwing out stuff. Good luck - keep us posted on what you find.
          • #6
            Yes, it started out slow while it was running so I thought it might be a head gasket, but the motor wasn't skipping at all. I ran it again the next day and slowly more and more water started streaming from what I thought was the side of the block so I figured a cracked block. I checked the oil and it is a little on the high side, but not milky so I am scared water has gotten into the oil pan. I looked down the oil fill cap and the rockers look clean so I don't know what the hell is going on. The boat had been sitting without be winterized so it could be a number of things... I am hoping just the manifold is cracked and I can replace it, but I want know until I get it off....I should have my OEM manual by next week and pray for the best...
            • #7
              Here is the mercury manual for your engine in digital format...........
              • #8
                Ayuh,.....
                I think you're going to find a big Crack in the side of the block, just below the deck........
                Just above that rust.....
                • #9
                  Thank you so much brother!! This will help so I can go ahead and get started.
                  • #10
                    Originally posted by Bond-o View Post
                    Ayuh,.....
                    Hey brother, you were 100% correct! I tore it down last night and as you can see from the pic it is BAD! Crack is 10 inches long. I have been in touch with "Lock-N-Stitch" and they are going to supply me with the pins I need for repair. I hope it works as good as they claim it does, so wish me luck. I will keep pictures updated with the progress and the finial outcome.
                    • #11
                      Thats the same place mine was cracked:
                      WAITIN' FOR SUMMER!
                      2007 Ebbtide 200 SE w/ 4.3 Merc
                      sigpic
                      SOLD ----> 1987 16.2' ThunderCraft Regency 3.0 Merc
                      LESSON LEARNED: ALWAYS CHECK COMPRESSION BEFORE YOU BUY!
                      • #12
                        With that size crack OUTSIDE, I would be seriously worrried about an internal crack that you can't see. One that will fill your oil full of water in short order. Won't happen if the crack is smaller than the outside one, as the pressure won't be there. If I were in your shoes, I would be looking for another engine and not throw money at that block at all.
                        Don S.
                        Please, no PM's (Private Messages) regarding boat/engine problems.
                        That is what the forums are for.
                        Only forum/moderator issues will be answered in PM's.
                        • #13
                          Hey brother, did you trash the block??
                          • #14
                            Don, I do have water in my oil, so there has to be a crack internally correct?? So you are saying if the crack on the inside is smaller then than the one on the outside I want get water in my oil??
                            • #15
                              I think he is saying that with an external crack that size & an internal crack that is putting water into your oil, that your block is toast & it is time for a new engine.....
                              Disclaimer!: In my inexpert opinion......
                              Back to Top
