96lt4c4
- Jan 8, 2008
- 110
Well actually my second. I took it out yesterday and it ran horribly, the timing was way off. I was running on a factory GM TBI timing map. It started to rain so I had to load it up. I did some research last night and found the factory timing curve for a 350 Mag. I manually entered that timing curve into my ECM. I did a little more tuning in the driveway this morning to make sure everything else was good to go. We took it back out. WOW!! its like a totally different boat. It gets up on the water fast! I have to be quick on the trim to get it up to speed. In the video I got it up to 50 mph like it was nothing. Later I pegged the speedo with a little more trim, I don't plan on doing that very much. Check it out.
The ticking in the video is coming from the injectors. Idle is set to 550 RPM. The boat goes in and out of gear very nice.
350 Mag timing curve
[/URL][/IMG]
