Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Boggs on Acceleration?
  • Boggs on Acceleration?
    i Have an 86 17ft four winns with a 4.3L in it. It starts right up, But uppon hard acceleration (in the gear only) It will Bogg very bad(stall if i don't let off). If i eas on the throttle it usually does fine. What could it be? It has new plugs, and wires. One thing i did notice is that the choke does not work and the butterfly just flapps around. I am going to try to wire it open. Could this be the problem?
    Re: Boggs on Acceleration?
    Quite likely. Acceleration means increased air flow thru the carb, which will pull the choke butterfly shut and flood the engine. Is a linkage off or broken? Wiring it open will make it hard to start next time out.
    • #3
      I don't think the choke has worked since i've had it. But the problem seems to be getting worse. I think the problem getting worse has to do with the plugs starting to foul from soo much fuel and not enough air. i;m in he process of a new cap/rotor and new plugs. I also have the carbs apart now for cleaning.
      • #4
        Sounds like an accelerator pump problem to me. Rebuild the carb which will include replacing the accelerator pump. That should solve your problem.
        Have a great day,
        Rob.
        • #5
          Check your carb kit!
          Merc kit does not include the accel pump plunger!!
          It is a seperate part that you NEED to replace.
          Sierra kit contains everything.
          • #6
            I suspect your accelerator pump is not working. There are two types of accelerator pump used on the 2BBL carb (You don't say which carb you have). If it is the 2BBL carb, you need to open the carb look at the accelerator plunger and then get the Sierra kit with the correct plunger. One plunger has a straight shaft, the other type has a 90 degree bend at the end of the plunger. Otherwise buy both carb kits and return the one you don't use afterwards.
            Gary
            • #7
              Ok, UPDATE!!! I rebuilt the carb, installed new distributor cap,rotor, plugs. and plug wires. Problem sill exists. Could it be the points? It's the 2bbl.
              • #8
                did you check to make sure the advance is working properly in the distributor? You can check the accelerator pump by just advancing the throttle and see if gas squirts in the carb
                • #9
                  How do i check the timing advance? when i pump the gas it does squirt into the carb but isn't it possible that its not squirting enough? could it be the points? how do i check them?
                  • #10
                    Yes it could be the points. You need new points more often than you do spark plugs. Also replace the condenser.
                    Then check the point dwell, and once in spec, set the timing.
                    To check the advance timing, you either need an advance timing light, or look and see how far past 0° it moves.
                    You can use the timing marks on the tab to determine the distance of 10° then put a mark on the vibration dampner around 30° and see if it goes near it at 3000 rpm.
                    You also have to have the idle MIXTURE adjusted properly. For it to accelerate smoothly.
                    Don S.
                    Please, no PM's (Private Messages) regarding boat/engine problems.
                    That is what the forums are for.
                    Only forum/moderator issues will be answered in PM's.
                    • #11
                      before i rebuilt the carbs it was doing the same thing, but when i rebuilt them i set the idle mixture screws back to stock specs. One was already there. and the other was way in. Now that they are both the same i don;t notice much of a difference. Should i move them in or out to try to help the problem?
                      • #12
                        Those "Specs" for the idle mixture are nothing more than preliminary adjustmenst to Get It Running for all types of engines. Nothing more.
                        After the engine is warmed up, they need to be adjusted to fit your engine.
                        Don S.
                        • #13
                          are they always going to be evne or will one side be more turned in or out? it really seems to idle good, the only problem is on WOT take offs. Which way should i try to turn them to improve? Could i be getting too much fuel? It is really acting like to much air.
                          • #14
                            I know you mentioned you had gas squirting into the throat when you worked the linkage, but was it good, solid streams? Could it be that the notorious check ball under the accelerator pump is missing? I know some carbs didn't have them, but the ones that did will most certainly act just as you're describing if the ball is missing. Some of the the gas that needs to be going into the throat is instead being shoved back into the fuel bowl.
                            This I know from first hand experience. The ball is about the size of a BB. In fact.....mine IS a BB.
                            • #15
                              ok, so today before taking the carb back apart and checking the ball i noticed that the accelerator pump arm wasn't fully extended. i also noticed upon disconnecting the arm that it wasn't really squirting untill it got past the part where it was stopping when the throttle linkage was hooked up. i bent the linkage more straight so the the arm gos up farther, and the problem got better, but it still doesn't squirt till towards the top. Could the ball be leaking? It seems like the pump doesn't pressurise very fast. the kit i had did have the balls with it, but i did not replace them. should i run some cleaner through it and see if it helps?
