Is it a good idea? I have a 170hp 2 brl in a 26' Starcraft Islander. It weighs in around 4k or so and is underpowered. Since I just bought the boat I have not had the chance to get it out but a compression test shows 80lbs in the #1. I'm thinking of rebuilding the motor boring 90 over and putting a performance aluminum head in it. Is this a good idea? If I do the 90 over what displacement will it be? I'm hoping to milk upwards of 200 HP out of the motor but more is better since the boat is rated for 270.
I'm looking for the best path to something in the 200-225 HP range while minimizing weight and maximizing efficiency. I'm comparing my cost/benefit of redoing this motor, replacing it or just going with an offshore bracket and outboard. The last option being the most desirable but it would probably be around 20k of which most of the cost I will never recover in resale.
What can I milk out of the 470 block and is it worth it? The cheapest way out would to maximize what I have and overcome the 470 weaknesses by replacing those components.
Ideas?
Ideas?
