Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
what does cracked bellows cause? safe to run?
  • what does cracked bellows cause? safe to run?
    Hi all,
    I have a 1990 Four Winns 225 Sundowner with a 5.8L OMC/Cobra drive. I noticed while working on my outdrive tonight with it all the way up that my black rubber bellows are definitely cracked and have holes in them.
    What will happen if I run the boat with this cracked bellow? I see where it attaches to the transom side but can't quite see how it attaches to the drive. How does it attach and is it hard to replace? Any suggestions on where to get this part?
    Thanks,
    Jeff
    Re: what does cracked bellows cause? safe to run?
    If it's the ujoint bellows, your gimbal bearing, ujoints, and probably the outdrive will all have water in them. Water is not a good lubricant. and starts destroying parts in short order.
    If it's the exhaust bellows, they come with holes in them.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      If its the u-joint bellow about $600 in parts. Gimbal bearing, u-joints, gear end yoke, yoke seal plus the bellow thats cracked. Thats if one of the above doesn't let go and sink your boat. Fix it asap!
      ~J
      • #4
        I think it may be the exhaust bellow as it actually looks like the holes are supposed to be there.
        It is the one you can see very easily with the drive tilted all the way up. Looking up underneath it is easy to see.
        Is this the exhaust bellow?
        • #5
          Yes,the bottom bellow is the exhaust.The aftermarket OMC bellow was designed that way for exhaust relief.
          Its the larger upper bellows that need to be sealed water tight.
          Usually if it fails you will get water in the bilge and ujoint and gimbal bearing damage.Sometimes it will show up in the drive oil also.
          Have you drained the gear lube to check for milky or foamy oil?
          Gear lube should be changed every season along with removing the drive and greasing the ujoints.
          1981 ChrisCraft 210 Scorpion K,175 Johnson SeaHorse
          • #6
            I wish I would have differentiated the difference before i had my marine store order the parts....
            Currently: 1994 VIP Vindcator 23' 454 with Mods, BR1
            1973 Taylor SS 19' Jet, 496 Stroker, Berkley Pump, Hydraulic Place Diverter - WANNA BUY IT?!
            1973 cobalt tri-hull. 140 mercuiser. pre-alpha. SOLD
            1985 SleekCraft Ambassador 26' Volvo AQ290A and 290 drive. SOLD
            • #7
              So now I know thanks to you guys that my lower bellows is the exhaust and is supposed to have the holes in them on my OMC.
              I have not drained the gear oil to check for water, I did top it off and oil on dipstick looked very clean but I will go ahead and drain it and refill it to be on safe side.
              Do you have to remove the whole from boat to grease the u joints?
              Thanks,
              Jeff
              • #8
                Thanks,
                Jeff
                Yes. You need a manuel. Refill it the wrong way & you can kiss your drive goodbye.
                • #9
                  The drive will have to be removed to grease the ujoints. That may be a job for this winter if you feel the ujoint bellows are ok.
                  To fill a Cobra drive,remove the top dipstick plug if it has one.Then the lower drain screw as well as the middle one.Let drain.
                  Start filling very slowly from the bottom hole.When it comes out the middle hole screw that plug in.Keep filling very slow until it shows full on the dipstick with it just resting in the hole.Then screw in dipstick and install bottom plug.
                  After the first run check the level on the dip stick.
                  My 4.3 Cobra held exactly 64 ounces,I think yours should be the same.I know the King Cobra holds more.
                  You need to invest in a factory manual before removing the drive.There are some critical shift cable adjustments to be done when the drive is pulled.
