Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Mercruiser Magnum 350 Engine Specs?
  • Mercruiser Magnum 350 Engine Specs?
    Two weeks ago I picked up a Cobia 197SRV with a Magnum 350, and was told by the previous owner that the motor had forged internals. The boat is a 1988, the original engine was replaced with a Mercury Marine part#14152A 1 long block in 1994. This part is currently out of production so Mercury couldn't give me any specs. This engine appears to have aluminum heads. My question is if this block features 4 bolt mains, forged pistons and crank. If anyone has any info it would be greatly appreciated.
    Re: Mercruiser Magnum 350 Engine Specs?
    Forged pistons and aluminum heads indicate not a stock 350 magnum. If it is a stock engine, its from Mercs race engine line. If it is, seems like Merc would have a service manual on it.
    • #3
      What is the engine serial number?
      • #4
        Haven't gotten to the serial # yet, I hear it's on the starboard side rear. There is a small tag on the rear of the port side valve cover with numbers on it, but I have to climb in with this big ole' body and try squirm in there to see wit a magnifying glass. What makes me say the heads appear to be aluminum is the fact that the front an rear surfaces of the heads where the accessory brackets bolt up to are mirror smooth, no rough casting or casting marks.
        • #5
          Try to put a Magnet on 1 of them..........
          That'll tell you......
          • #6
            Okay, they're cast iron, I climbed in and saw a little rust around a threaded hole. Of all the stock small block Chevy factory heads I've seen, none has this smooth of a surface. These are also definitely not Vortecs though. As far as the serial # goes, I have to use a little emery to clean off the block to see it.
            • #7
              A stock 350 mag does not have 4-bolt mains or forged pistons, but many people "believe" it does.
