Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
TDC where should my rotor be?
  • TDC where should my rotor be?
    Help please!
    Piston 1 is at top dead center. Should my rotor point to spark plug 1? If it's supposed to point to another one how do I go about doing that?
    My engine is 1970 - AQ130c
    Thanks
    Re: TDC where should my rotor be?
    Yes, but you need to make sure it is at TDC on the compression stroke...
    Put your finger on the #1 spark plug hole & make sure you feel compression as you turn the engine to get to TDC.....
    Disclaimer!: In my inexpert opinion......
    • #3
      Or do what I do. Take a compression guage hose and put it in the spark plug hole Tap crank the motor over lightly till you start hearing a PPPSSSHHHTTT coming out of the compression guage hose. it may take a couple of tires but its a truck my buddy showed me and it never fails
      Rob
      • #4
        Once you actually get #1 piston up on TDC of the compression stroke, no matter where your rotor is pointing, that will be where #1 spark plug wire should be on the distributor cap.
        Why are you having this problem to begin with????
        Don S.
        Please, no PM's (Private Messages) regarding boat/engine problems.
        That is what the forums are for.
        Only forum/moderator issues will be answered in PM's.
        • #5
          If the rotor is not pointing to # 1, there's several options.
          1, lift the distributor up 1", turn the rotor to just past #1, (to allow for the bevel gear rotation) and set down, clamp.
          2, if it's close to # 1, turn the distributer in place,
          3, change the wires to the appropriate terminal.
          #1 is preferred but whichever you choose, you will have to time it with a light after.
          • #6
            Unless you know what a 130 Volvo is, be careful what you suggest.
            Don S.
            • #7
              don't do what i did an mark the timin marks in the wrong place on that timin mark pointer thingy. the dang thing won't ever run right.
              • #8
                To answer you question Don, I changed over to electronic Ignition yesterday. I started my engine up yesterday with no problem. I started my motor this morning with no problem, so I was going to re-time my motor.
                As I was getting ready to do the timing I noticed that my RPM was all over the place, this happened only when I throttled up, at idle it stayed right at 900 rpm. Problem is I need to be at 2000 rpm to time the motor. This is where everything went to hell in a hand basket.
                As I tried to fix the fluctuating RPM by trying some carb adjustments I ran out of gas (I know, I know shoulda done this with at least a 1/4 tank.) Anyhow I filled up. Then my motor wouldn't start up. I checked my fuel filters (had to replace one of them) I blew compressed air through my fuel line to clear the muck from the pick-up tube. So to make a long story short my fuel is flowing properly (checked and re-checked this).
                I've turned my dampener to 0 (that put it to TDC, my finger was getting pushed off by pressure from the cylinder). That's why I was wondering if the rotor was supposed to be pointing to #1.
                Here's another tid-bit of info, my #1 and #3 plug are soaked, #2 and #4 have a real dry almost sooty look. #3 and #4 have a brownish tinge to them. I need somebody to help me with a read on those plugs. Should I replace them? The plugs are 2 years old but only have 1 season on them.
                Thank again and I look forward to your responses.
                • #9
                  The motor RPM's are all over the place or the gauge is reading all over the place?
                  Watch this space......................
                  • #10
                    The gauge reading it was all over the place.
                    • #11
                      Could you hear the engine rpm change? or just the gauge moved?
                      Don S.
                      • #12
                        I was able to hear the motor change rpm also.
                        • #13
                          Sorry to hijack, but basically same question. I have an OMC 460, freshly rebuilt and I am trying to switch to a distributor.
                          Once I have #1 piston at TDC, the rotor is pointing to the spot on the cap where the #1 PLUG WIRE should go, right. I am a little confused since I am reading this and think someone said it should point at the #1 SPARK PLUG, not the terminal for the wire on the cap.
                          I haven't messed with a distributor in a long time, my memory was that on a new motor/distrbiutor, you went TDC and then placed the wires on the cap to correspond with the cylinders that are firing. Right? Wrong?
                          • #14
                            Turns out my coil is shot. I did the test where you pull the center wire and put it up close to the block and look for an arc. My coil put out a wimpy little orange arc. I double checked the test by jumping my boat battery with my running vehicle, just to make absolutely sure I had max voltage, my coil still pumped out a wimpy little spark.
                            It's too late to get a coil tonight, but can anyone tell me what model coil I need for my AQ130? I'd prefer to go with a Bosch, I currently have some no-name coil in my boat.
                            • #15
                              You're correct Don, I don't know.
                              Does that mean it's not a basic GM 4 cylinder with a regular marine distributor?
                              Back to Top
