Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
stern drive leaking out weep hole
  • stern drive leaking out weep hole
    i just purchased a used sea ray open bow. 1997 merc 3.0. i used it 3 times and now the stern drive is leaking fluid out the weep holes???? in my driveway is this bad or something simple????
    Re: stern drive leaking out weep hole
    Water or oil?
    • #3
      Where are these weep holes, maybe in the exhaust bellows? What type of fluid? Are y ou sure that it wasn't doing it before? Need some more info before your questions can be answered.
      Have a great day,
      Rob.
      • #4
        yes, green oil. ive had the boat in the water 3times and didnt notice before, but maybe i just missed it.(doubt it). weep holes are where the top and bottom of the stern drive bolt together. one on each side. oil is only coming out of the (right or same side as boat driver). i didnt know i was supposed to lower drive when in drive way. would that make a difference??? thanks a bunch for your time.
        thanks chris schwab, puyallup, washington
        • #5
          What outdrive is it? Are you refering to the port where the oil passes between the upper and lower? If so, thats an eay fix, seperate em and replace the small gasket there. Or are the weep holes vent holes? If thats the case, then you probabily got water in there. Take out your bottom drain plug with a pan under it. If water comes out first(oil being heavier than water), then oil, you know what your problem is, now you just have to trace it down. Could be a bad impellor housing or maybe a bad seal
          1986 Chris Craft Scorpion 178 GM 3.0 140hp first gen alpha 1
          • #6
            There's an o-ring that seals the passageway where the 2 halves meet. You need to separate the bottom and check to see what kind of shape the o-ring's in.
            • #7
              If its coming from the weep hole then you are leaking at either the lower seal on the upper housing or the shift shaft seal in the lower housing. If I was a betting man, I would say its the shift shaft seal.
              • #8
                If it's leaking here, then as others have said it could very well be the lower shift shaft seal.
                1980 Sylvan Aluminum 18' Sportster I/O - Mercruiser 140, Honda 7.5 Kicker, Bennett M120 Tabs
                1974 Glastron V-179, Mercruiser 140
                1984 16.5ft. Alumarine Sealark side console with 82 Merc 50
                Manitoba, Canada
                • #9
                  I had oil leaking there, and it turned out to be the lower seal on the driveshaft housing. The only special tool you will need to do this job is the retainer ring wrench. It's not that bad a job.
                  1989 Glastron GX-216 Ultra
                  350 Mag/Alpha 1
                  Clarks Hill Lake, Georgia
                  • #10
                    I concur with Capt. Ken...shaft seals
