I thought I was finally ready to put the 74 formula in the water when I noticed a slow drip from the fuel inlet (where the steel line attaches) on the carb. The engine is a 302 ford and I believe the carb is a 4160. I took the line off of the carb and then removed the fitting which screws into the bowl only to find slivers of metal! After removing the bowl, I could look inside and see that the son of a gun was stripped. I can buy a brand new bowl for $74, but someone has to make a helicoil that size, right? Anyone know where I can find one or happen to have a better idea?
Thanks in advance for the help.
