Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Holley 4160? stripped fuel inlet!
  • Holley 4160? stripped fuel inlet!
    I thought I was finally ready to put the 74 formula in the water when I noticed a slow drip from the fuel inlet (where the steel line attaches) on the carb. The engine is a 302 ford and I believe the carb is a 4160. I took the line off of the carb and then removed the fitting which screws into the bowl only to find slivers of metal! After removing the bowl, I could look inside and see that the son of a gun was stripped. I can buy a brand new bowl for $74, but someone has to make a helicoil that size, right? Anyone know where I can find one or happen to have a better idea?
    Thanks in advance for the help.
    Re: Holley 4160? stripped fuel inlet!
    Auto zone, etc , has kits , as you ain't the cherry to do that.
    • #3
      Sweet, I'll have to check tomorrow! Hopefully I can finally get this beast in the water now that summer has almost passed us by...
      • #4
        You may want to go to a salvage yard. Ford used Holleys on some of their pickups from 85-95 at least. As far as I know, there's no helicoil that fine of thread. What I would do is not put the filter in there and find some fuel proof epoxy for the threads, not the gasket. It may not be a permanent fix, but it should get you through the season.
        • #5
          But,
          If your "fix" leaks it may kill you or one of your family!
          You need to REPLACE either the carb or rebuild it using a new bowl.
          Are you going to let $74 compromise safety?
          That 4160 is a pretty good carb. I have one that came off my "old" OMC 460. It was the best part of it!
          Regards,
          Rick
          1987 FourWinns 211 Liberator, Originally OMC 460 King Cobra.
          Re-powered in 2006 with a 1997 Mercruiser 7.4L Bravo III
          THERE IS NOTHING LIKE A GOOD OIL "THREAD"!!!
