Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Can you start an inboard/outboard out of water???
  • Can you start an inboard/outboard out of water???
    The boat in question has a 1988 5.7 mercruiser in/out. Was started for 10 seconds out of water. Now i know how bad it is for an outboard to be started out of water, i'm just not sure if it's the same thing with an in/out?
    Re: Can you start an inboard/outboard out of water???
    A merc outboard has the same raw water pump in the drive as an outboard. So, now you know what damage may have been done.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Thanks!
      • #4
        Not good, but 10 seconds probably isn't going to kill it.
        • #5
          buy a set of Muffs for it. hook it to your garden hose and your good to go.. i just bought a set on e-bay for $9.95. + 4.95 shipping..
          • #6
            15.00 for muffs? I think i paid 5.00 at walmart. They are only 7 at the boat store. Hope you got the good ones.
            • #7
              I also have the $5 WalMart ones. They work just fine.
              2006 Bayliner 175 "All 4 Tweety"
              Custom 2 pc. Cockpit/Bow Cover Set, Family Fun Pack, 3 Step Swim Ladder, Smart Tabs, 13.75 x 21P SS Prop, 5.25" and 6.5" Sony Xplod Speakers, Garmin 172c GPS, 400w DC to AC Power Inverter, Dual Batteries, Guest Isolator, Dual Faria Voltage Gauges, Faria Hour Meter, High Flow Exhaust Tube, K&N Flame Arrestor, K&N Oil Filter, Royal Purple Synthetic Motor Oil, Royal Purple Synthetic Gear Lube, 12v Power Port, Blue LED Underglow Kit. GPS'd @ 47.3 MPH
              • #8
                Replace your water pump. It's cheaper than a head and a tow.
                • #9
                  head and toe?
                  is that like an arm and a leg?
                  or, are there very friendly tow operators in VA!
                  • #10
                    They are not the Chepo wally world ones.. i saw those .. no thanks
                    • #11
                      been using the wally ones for several years no problems if you know how to take care of them
                      • #12
                        I've found 2 different types and 1 looks alot better quality than the other.
                        http://www.************/webapp/wcs/st...002000_200-2-7
                        • #13
                          I use the second pair that you showed and didn't have a single prob. water pressure from hose is the same with either one.
                          sigpic
                          1991 Bayliner Capri 2050CX,4.3L V6,Mercarb 2bbl,Alpha 1
                          (QUOTE): When our boat is happy, THEN we are Happy
                          Back to Top
