Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Oil Pressure switch Diagram
  • Oil Pressure switch Diagram
    anyone have a wiring diagram for the 3 prong oil pressure switch and how to properly wire the elsectric fuel pump to it? thanks.
    Re: Oil Pressure switch Diagram
    This is a Mercruiser 2 wire switch.
    Of those who receive good advice, only the wise will profit from it.
    If you need it....Get it
    If you want it....Wait
    If you have it....Flaunt it
    • #3
      see the thing is the guy had it wired to a toggle so you could hold the toggle, prime the pump and fire it up if it sat for a while. well i dont even think the starter solenoid terminal has a wire to the switch on it, and when it died in the water all of a sudden, the two wires i took off the switch when touched energized the pump even with the key totally off. so i think i will wire it as you have it and if there is still a problem, then replace the switch, also there are 3 terminals on my switch but i should only need 2 of them correct? which ones go to which wires?
      heres how i gather this to go, i need a wire from the starter solenoid to go to the pump, then i need a wire from the actual ignition switch(where the key is) to go to the oil pressure switch and then from the switch to the pump? so the fuel pump should have 3 wires to it then on 2 terminals. one ground, and 2 power sources? i hope thats correct. thanks for the quick reply.
      btw its a 1990 omc king cobra 4.3L, idk if thats the same as the merc or not. thanks
      because the actual problem was it was running fine and then died. would restart after i held the toggle to give it gas, then restarted and ran that gas out, the fuel pump was not getting power while engine was running, so that tells me the switch could be bad or bad wiring.
      • #4
        For Mercruiser color codes, the YEL/RED starter wire connects to the normally closed switch contact, the PUR ignition wire connects to the normally open switch contact, and the common terminal goes to the fuel pump.
