MercMonster
- Jun 3, 2007
- 151
I'm looking to see if anyone has the torque sequence for a mercruiser head for a 165HP Inline 6. As posted earlier, I have a block with GM 82 stamping. So believe that's what I'm working with here. Still waiting for the manual to arrive (is coming postal). I'd like to get a head start on removing it today, while I have the time and gumption. Got the spark problem fixed and put on the muffs, she is singing along, but dumping water into the oil. Also, the oil pressure is low (about 20-25 lbs. on the gauge). Can this be attributed to water in the oil or is it necessarily a pump going bad? Bad gauge? Don, per your earlier suggestion, I am replacing all the components there..... Also could use the torque sequence for the exhaust manifold if anyone has that handy for reference.
