Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
marinizing smallblock Chevy engine
  • marinizing smallblock Chevy engine
    I recently came apon a boat that I can have for free if I will haul it off. Regardless of condition I am going to get the boat then decide whether its going to the heap or not. It has a smallblock Chevy 305 engine in it. The current owner explained that he let the factory engine freeze and replaced it with a 305 he had. He mentioned he bought manifolds for it and had the short block rebuilt using a marine cam. The intake and carb are automotive.
    I would like to repower my old cruiser. It currently has a 273 Chrysler inboard so I think the Chevy has enough C.I. to do the job. My question is wether or not it is worth my time and money to completely marinize and build a fresh 305 Chevy engine for my repower. I am considering it simply because I will be getting the complete engine free and regardless of what the previous owner says, I would have to go through the engine before I did anything with it. So my logic is to build me a fresh, properly marinized smallblock out of the free engine or, forget the idea because it would be better to rebuild the already marine. Chrysler. Any advise?
    "Your results may vary"
    Thundercraft in Progress
    http://forums.iboats.com/showthread.php?t=287390
    Tri-hull Wiring
    http://forums.iboats.com/showthread.php?t=448376
    Re: marinizing smallblock Chevy engine
    not an i/o person, but if it has the marine cam, and he's go the marine manifolds, it's the add on that have to be changed, alternator, carb, fuel pump, ignition. will it mount up to your drive?
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      Auto carb in a boat is a huge NO-NO!
      There is nothing in a SBC that would bolt up directly to your existing setup. You'll need to investigate what it takes to bolt up your existing driveline to the flywheel and bellhousing of a Chevy block. The manifolds would have to be retrofitted as well. Then there is the issue of the gear ratio, if it is correct for the engine you do install.
      sigpicIf it were easy, any Caveman could do it.
      • #4
        What is the difference between a marine carb and automotive carb??
        1984 - S2 Yachts - 23' Tiara Continential - 260 mercrusier - alpha 1 drive
        • #5
          It's All about how Spilled Gas is dealt with........
          With Marine Carbs,......
          Any Spilled Gas is directed down the Throat of the Carb,......
          Not all over the motor........
          You're Really Over Thinkng this thing,.........
          The Chevy IS a Marine Engine,....
          Though I don't know about the Peripheral Parts that were bolted to it.....
          Mainly the Carb....
          The Issues you need to be Thinking about are brought up by Kagee,+ to a point, TD.......
          And That's making the Chevy Fit in the Chrysler's place............
          • #6
            Basically the overflow is directed to the throats so there is no spillage outside of it. They also have a fitting for a hose from the mechanical fuel pump if the diaphragm should fail. On a car fuel pump, the leak would go into the bilge and BOOM. Marine fuel pumps also have double diaphragms.
            Electrical components are made to contain inherent sparks which would also make your boat go BOOM. Car motors are ventilated. Boat motors are enclosed. Leaky car motors leak out of the car. Leaky boat motors leak into the boat.
            Among major internal differences include some to all of the following:
            Forged pistons
            Forged rods
            Forged crank
            Heavier valve stems
            Larger valve guides
            Heavier valve springs
            Roller lifters
            Heavier push rods
            Remember that a car smallblock will rarely see the 4800 RPMs that a marine smallblock is made to run most of it's lifetime. Car smallblocks have a huge longevity problem when put into a boat. Heavy duty truck smallblocks will have far more of the above than a car smallblock.
            Do people put car motors into boats? Yup. But they don't last and they have a multitude of potential sources to blow your boat up with you in it.
            Hey, Have you seen? They make Really Cool life preservers nowadays.
            So "Looking Dorky" is no longer an excuse for not wearing one.
            • #7
              I can't find my link at the moment. The differences are small, but when it comes to safety, very important.
              It is also illegal. If there were an accident directly related to the use of a non-marine approved carb, starter or alternator, you would have Civil and possibly Criminal liabilities if there were injury, death or other property damage as a result of the unapproved items.
              • #8
                Forged pistons
                Forged rods
                Forged crank
                Heavier valve stems
                Larger valve guides
                Roller lifters
                Heavier push rods
                I'll preface this with,....
                We're talking about Standard Production Marine Engines,.......
                Not the High Preformance motors,....
                Not the Magnum Series,......
                Just the Standard Production Marine Engines,......
                That Said,..........
                Your post is Wrong Willy,........
                The Standard Production Marine engine is the Same as the Standard Production Pickup Truck motors of the same Vintage.........
                Just add Brass Coreplugs,+ it's the Same Motor..........
                Even the cut of the Cam is So Close you'd Never be able to Tell, without a Dial Indicator,+ Degree Wheel......
                From your List,.....
                None of them have Forged Pistons,.. None.....
                All SBC Rods are Forged.........
                None of them have Forged Crankshafts,..... None.....
                Same goes for the valve stems,...valve guides,... valve springs,+ push rods.... All the Same Parts.....
                The Roller Lifters are a Vintage thing,..... When Chevy started putting them in Pickups,..... Merc. started putting them in Boats......
                • #9
                  The engine in the free boat I am getting is not a marine engine. It is a standard 305 out of a truck. the previous owner installed it in the boat with new marine exhaust manifolds and a marine cam. (he froze the factory engine and replaced it with the truck 305) I am aware that I would have to get marine induction and ignition and all the do-dads to run the thing. I am aware that I will need a bellhousing to bolt it to my velvet drive (1:1). Based on my conversation with the previous owner, I am sure there will be several items I will have to get.
                  Intake, carb, ignition, raw water system, risers to fit my existing exhaust, marine fuel pump, probably a oil pan to fit boat ect....
                  You think it is worth it? Or should I just rebuild the Chrysler I already have? I not consider building the Chevy, but It will give me an engine to get ready while I run the Chrysler. It still has allot of life.
                  Tri-hull Wiring
                  • #10
                    Not telling you what to do, but if it aint broke, don't fix it!
                    • #11
                      There must be a ton of 318 and 340 Mopar engines out there that would make an easier swap and increase power with far less modification.
                      • #12
                        Bondo, reread. He asked about car smallblocks. My facts are facts. Truck smallblocks have most of what he would need. Car smallblocks would have less. That is what I said. And marine cams aren't just lift and duration, but timing and overlap as well (and probably foremost). My list is more of a "most to all of the above" rather than an "all of the above". It depends on the model. But he has a Chrysler motor anyhow and it's all moot. I have no idea what would be different between Chrysler automotive and marine engine internals.
                        • #13
                          Willy my OMC Factory manual Says to see my local Chevy Parts dealer for all of the engine internals.
                          • #14
                            The previous owner of the free boat I am getting says that marine v8 engines have a higher nickel content.
                            Gimmi a break, the BS never stops.
                            Tri-hull Wiring
                            • #15
                              My facts are facts.
                              While your Facts are Facts,......
                              The way it's presented Isn't........
                              Your post Easily leads to the Rest of the BS that is spouted about Marine Engines,.......
                              Just like This BS,.......
                              Point Is,.........
                              For Rebuild Purposes,..... A Long Block Core motor, Right out of a Car in a Junkyard,.....
                              IS in Fact the Perfect Core for a Rebuild..........
                              'cause a SBC is a SBC.........
                              Btw,.... I know there's More to a Cam Cut than Lift,+ Duration........
                              Matter of Fact,....... The LSA is about the Most Critical # to pay attention to when buying a Marine motor's Cam......
