brown bombuh
- Aug 28, 2006
- 7
I had a cracked manifold, and replaced it with a GLM aftermarket unit.
I have some concerns about the quality of this part, and am wondering if my experience is typical or if I got a bad unit.
Upon removing it from the box, I imeadiatly noticed the paint was flaking right off, and that the paint had been aplied right over casting residue (foam, sand etc). And that there was painted over casting debrie in all the ports etc.
After using a wire brush and compressed air to blow most of the crap out of the manifold, I noticed the casting had porosity as evidenced by voids in the machined mounting surfaces.
I went ahead and gave the exterior another coat of paint, but removed the paint from the machined gasket areas to get a better seal.
After installing the carb. I noticed that the machining is off...the carb is not centered over the manifold, it is offset about 3/8" to the front, so that part of the casting is partialy blocking the front half of the port. the heat riser for the choke was also the wrong diameter to accept the choke heat tube. The waterjacket locations at the riser had also been changed sligtly, and wheren't a good match with the original mercruiser riser.
Since I had allready repainted the manifold I didn't call the vender to ask about an exchange or refund etc.
The price was right, but the quality now seems really suspect on these aftermarket parts.
Anyone else have simialr experiences?
SHould I try to elongate the manifold port so as not to partialy block the base of the carb?
