Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone elses topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when its posted at the end of someone elses topic. And those answers will be specific to your particular issue.
See more
See less
Gap setting for plugs on a 3.7 470 Merc
  • Gap setting for plugs on a 3.7 470 Merc
    I need to confirm plug gap setting on my 470. Its an 84 Mercruiser. The Manual spec I have shows 25 to 30 on the plugs and 17 on the points.
    When I pulled the plugs that were in the boat the plug gap was in the 35 to 40 range.
    I am figuring the manual spec would be correct but wondering if there would be a reason to over gap.
    THanks
    Re: Gap setting for plugs on a 3.7 470 Merc
    Not sure what manual you are getting your specs from, but they are't what's in a Mercruiser manual and way off from the specs.
    The 470 should have a plug gap of .035"
    Points should be gapped at .022" then checked with a Dwell Meter and readjusted to 28° to 32°. Then the timing has to be reset to 8° BTDC @ idle rpm of 650 to 700 rpm
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Thanks Don, The manual spec I got was from the Marina yesterday where I got the parts for a full tune up. He looked it up while I was there. So much for that.
      The reason I wanted to confirm is because the plugs I took out had a much larger gap and got me wondering
      . I guess I will stick with parts only from the guy I spoke with yesterday.
      Is there a technical manual I can get for the Mercruiser model motor? Motor S/N 6890496
      Most of the ones I have seen on line are for the 3.0 not much on a 3.7
      Thanks
      • #4
        You need service manual number 3 for your engine, it's part number 90-95693.
        Your local Merc dealer can order you one, or you can order one directly from Mercruiser.
        https://appcenter.mercurymarine.com/...rm.jsp?type=mc
        If you order from this link, add a 0 to the front of your serial number.
        No manuals online for your engine that I am aware of.
        Many have found them on ebay.
        Don S.
        • #5
          thanks Don I will get one ordered
