tonyvail said:I spent the weekend installing one. The cable cost $170.00 and I got prices as high as $225.00 You need a $10.00 seal of which I destroyed trying to reinstall the lower unit. I called around and received total quotes in the $800 range. I spent all weekend on the project. The motor had to be moved six inches as it was in the way of installing the cable. I think that moving the engine changed the alignment, and now I will still have to take it to a shop for an alignment and install of the lower unit. It is one difficult job! I would break it down as $200 in parts and approximately $600 in labor if there are no unexpected problems....also, I am talking about the lower shift cable. This is the one that usually needs replacing. There are two upper cables. They are about $30 each and involve much less to install. I replaced those last year.
tonyvail said:tonyvail said:I spent the weekend installing one. The cable cost $170.00 and I got prices as high as $225.00 You need a $10.00 seal of which I destroyed trying to reinstall the lower unit. I called around and received total quotes in the $800 range. I spent all weekend on the project. The motor had to be moved six inches as it was in the way of installing the cable. I think that moving the engine changed the alignment, and now I will still have to take it to a shop for an alignment and install of the lower unit. It is one difficult job! I would break it down as $200 in parts and approximately $600 in labor if there are no unexpected problems....also, I am talking about the lower shift cable. This is the one that usually needs replacing. There are two upper cables. They are about $30 each and involve much less to install. I replaced those last year.
