Did some outdrive work last year and installed it myself with new rings and oil. The throttle cable was well lubed. The outdrive went on after much cursing and the final boot kick seemed to get it onto the bolts.
All season, I've noticed the shifting to be stiff. Sometimes smooth, other times hard to move the shifter in or out of Neutral. When in reverse, it sometimes stays in reverse -- even though the shifter is in Neutral. I've had to put it back into reverse and then back into Neutral and it's 'fine'.
So I'm guessing that the shift mechanism in the outdrive may be a bit out of place. Maybe it's 'fine'. Is it possible to install the drive and have the shifting mechanism create these type of problems? First thought is to uninstall the outdrive and get it in there smoothly and correctly? My lower back doesn't want to tackle the lower install again. I have a homemade drive stand -- but it doesn't line up perfectly for that finishing move -- all stooped over and the lower back pays the price.
Maybe a new throttle cable? That would be a mechanic job, probably beyond my skills?
Thanks Gang!!
Thanks Gang!!
