cableguy1979
- Jun 25, 2017
- 121
I just got through talking to the guy I got the boat from and he tells me that the boat had about half a gallon of water in the bilge after about a month of boating so Im panicking and wanting to check for where the water is coming from but the boat isn't ready for the water. I still need to put on the lower, have the prop refrub'd, dewinterize, put seats in the boat and figure out why the engine is idling high so im a little ways away from floating it. I have checked the bellows they look good. The bottom of the transom looks good and I don't believe the engine is leaking anywhere. I could always just back it down a ramp somewhere with the lower unit off....probably safer that flooding the bilge?
Hers my question.....can I safely flood the bilge up to the oil pan to check the transom seal? My worry is the lowest part of the transom where the sterndrive opening is. If memory serves that's usually wood surround by fiberglass. Im afraid if I get it wet it will be causing problems I don't want. If the transom is good I can rest and worry about the other things. If not then its time to scrap the boat. Will I be causing problems by flooding the bilge?
