Pull one of the plugs to see if you have spark, then work your way upstream till you find where you have spark again.
The code won't come up again unless the fault is still active.
You could still have an intermittent ignition fault somewhere else.
While the dist cap is off, check that the spring tab on the rotor is sitting up about 3/8" off the top of the rotor.
Try cranking the engine in the dark to see if it's arcing. If do you see that, turn the lights back on and look for carbon tracking on the plastic.
You might check the coil for that as well since you're there anyway: old school coils were bad for that until they changed to the bakelite housing. Being SmartCraft, your coil is likely electronic and they're not usually as bad for that...but still worth checking. Serial number would help with that.
Not to state the obvious, but double check that the wire boots are fully seated, esp on the coil lead.
