Goldie627
- Oct 28, 2013
- 1,010
Hello all, im almost certain ill be taking out my engine for timing gears and possibly rear main seal. I currently have a manifold vacuum of 14. after the gear replacement i would like to start and run the motor on the ground before i put the motor back in the boat. that way i can compare my vacuum readings before and after the new gears as im hoping that the new gears will solve the late timing issue and increase the vacuum preasure
any and all tips for running the engine outside of the boat are welcome
thank you!
thank you!
