Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Trim down very slow Mercruiser MC-1
  • Trim down very slow Mercruiser MC-1
    Trim down very slow Mercruiser MC-1 sterndrive. The up is normal, and trailer is normal. I can go directly from the battery to the green line on the pump and it will go down real fast using a 6 guage wire. I can't figure out why it's so slow using the trim down on the throttle. It has a new solenoid, and new breaker. Any ideas would be appreciated.
    http://forums.iboats.com/forum/boat-...-and-pre-alpha
    Is this a new problem?
    Bt Doctur helped me in this thread.
    http://forums.iboats.com/forum/engin...-wiring-issues
    1980 Sylvan Aluminum 18' Sportster I/O - Mercruiser 140, Honda 7.5 Kicker, Bennett M120 Tabs
    1974 Glastron V-179, Mercruiser 140
    1984 16.5ft. Alumarine Sealark side console with 82 Merc 50
    Manitoba, Canada
    • #3
      Before the total rebuilt, it went down normally from what I recall, just didn't go up. Also during the trim bleeding process, I noticed a white colored oil in the reverse locking mechanism to pump clear hose. Dunno if that matters any.
      • #4
        Bump for answer!!
        • #5
          If it goes down fine when jumped, it sounds like a wiring problem.
          Check all connections.
          Manitoba, Canada
