Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
'76 Mercruiser shift cables
  • '76 Mercruiser shift cables
    Hi all,
    S/N: 4445247 (Mercrusier R Drive)
    Apparently '76 was the year they shifted from a 5 7/8" lower shift cable adjustment to 6". The previous owner appears to have mixed and matched hardware. The current lower shift cable uses a brass cylinder nut to anchor in place.
    Which length would you recommend setting the cable at?
    Thanks,
    -John
    Hey achris Bondo fella needs some help
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 SeaDoo GTX
    Raw Water Pump Maintenance
    Merc Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
    • #3
      a brass cylinder but should use a cotter pin to retain it in the housing
      Usually I put the control box in full fwd ,attach the plastic end to the stud and adjust the barrel to fit. Then check reverse and adjust the movable stud for proper operation
      NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
      • #4
        The moveable stud is the plastic one yes?
        Do you ever move the lower shift cable attachment point up and down? There is a slot in the aluminum.
        -John
        • #5
          2A-18 in here https://drive.google.com/file/d/0B1T...Uh5RElUQQ/view
          • #6
            You move the stud up after shifting to reverse and have someone rotate the prop to be sure it is fully engaged. Those service manuals were printed for when every thing is shiney and new not used and old. Do it just as the Dr. described.
            Kenner, Louisiana 1980 Donzi 18'. 2+3 6.2 MPI Alpha 1
            • #7
              In forward or reverse gear were getting a pretty noticeable clunk as we turn. Not smooth at all. Should it be that clunky?
              • #8
                ?As you turn what?
                Alpha drives need to shifted briskly into gear.the initial clunk is normal
                • #9
                  Ah no we're just spinning the prop, in reverse gear, with the engine off. It locks clockwise. How hard should it be to rotate counter clockwise?
                  • #10
                    thee is no need to rotate it backwards your just looking to be fully locked CW for reverse and no clicking in neutral
                    • #11
                      No clicking in neutral... It locks correctly in forward and reverse.
                      But should the prop, in forward, spin freely clockwise? Require 2 fingers to move it? 2 hands?
                      Phrased differently, how difficult should it be to move the prop in the correct direction?
                      Thanks,
                      -John
                      • #12
                        Would posting a video be helpful? maybe we'll do that tomorrow morning.
                        • #13
                          freely if the cable is not connected to anything and you rotate the prop shaft
                          if the shift cable is connected to the control box there will be a ratcheting sound as you turn the prop F is locked CCW and ratchets CW
                          R is locked clockwise and ratchets CCW
                          • #14
                            Brilliant, ok so here's where we're at...
                            I can adjust the forward motion to spin freely, however, when shifting into reverse, the CCW motion is very very clunky. Requires two hands to rotate.
                            There is 3" of travel on the upper shift cable. After playing with the lower cable, by hand, it seems that pulling it all the way extended actually makes it worse. If I had 2.5" of travel on the upper shift cable things would be smoother.
                            Going in the other direction, pushing the shift cable into full forward makes it very very clunky. The sweet spot seems to be: Push lower shift all the way in while friend counter rotates prop, then pull cable out 1/4".
                            Does that make sense? At what point do you "set it to spec and turn the engine on?"
                            Thanks,
                            -John
                            • #15
