1991 Sea Ray 200BR, 350 mercruiser I/O drive. Brief history. Boat has been sitting for the last 6 years do to the upper drive gears going bad. I finally replaced the complete outdrive last year. When I finally got into the water, there was such a lack of power in the motor. At full throttle I couldn't get it over 2000 rpms. This was last September. The boat sat again until this past August when I found out that both head gaskets were shot.
After ripping the top end of the motor down, I replaced the following :
Carb
Both Head Gaskets
Intake gasket
Exhaust Gaskets
spark plugs
wires
oil / w new filter
and changed the oil in the outdrive
Finally got the boat back in the water this weekend. I have 2 issues now. The first is that when I tried forward gear the shift cable would travel past engagement to wear the throttle kicked in before going into gear. Reverse went in immediately. Obviously the shift cable needs adjustment. 2nd was I still had no power. At full throttle I still couldn't get past 2000 rpms
1st things 1st. I'm trying to adjust the shift cable. Here's the problem. When I adjust the brass barrel to 6" like I'm supposed to the dogs don't engage until forward gear. I have reverse gear, but still no forward. I have to twist the barrel almost all the way till I have no threads left for the forward dog to engage, but then I have no reverse. I tried adjusting the post travel for reverse, but still nothing. I can't find the spot for both gears to engage.
2nd. While in the driveway, I can get full throttle. I can rev to 4000 rpms no problem. Butterflys open with no problem. Why the lose of power under load. I'm having the issue with the new carb just like the old carb. Seems like these problems both started happening after replacing the whole drive assembly
:mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new::mad-new:!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Carb
Both Head Gaskets
Intake gasket
Exhaust Gaskets
spark plugs
wires
oil / w new filter
