Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
350 mag v drive impeller pump
  • 350 mag v drive impeller pump
    I have a 2007 centurion c4 lightning with 5.7 black scorpion engine. Was on lake belt started swuicking open engine compartment and notice the impeller pump was not turning. How hard is the pulley or pump to change. What would cause the issue. Thanks for any help
    The hardest part of replacing the impeller for most folks is getting to the pump. Now since your pump was not turning, you either need to take yours apart and rebuild or buy new. If I had your engine serial it could be verified, but figuring you have Merc part number 46-8M0118068
    It is item 1 in link below
    http://www.mercruiserparts.com/bam/s...1440/10108/195
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 SeaDoo GTX
    Raw Water Pump Maintenance
    Merc Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
