My old outdrive took a strike and I had shavings on it each time I checked. The top cap of the upper portion of the outdrive had some corrosion on it. So we thought the upper gears had some problems overheating and leading to those shavings. So I went for the more expensive, total fix.
I've had the mechanic install a new gimbel, grease everything up and an entire new outdrive. Loaded up the gear oil and ran a few trips.
Now I'm noticing the same whit/grey discoloration on the top cap. Dropped the plug and found another wad of shavings.
This is beyond frustrating ... Any ideas are welcome. I'm headed back to the mechanic to see what he might think.
