makanik32@yahoo.com
- Jun 1, 2017
- 19
I have a mc-1 outdrive model number 4186702. The problem im having is that the shifter will not go into reverse, it appears to go into drive ok but seems to bind up going into reverse... If i disconnect the lower shift cable the shifter functions properly... I have adjusted the lower shift cable to get the six inches while pushing in on the cable, the drive locks as if its in drive ,but that didnt seem to help. I removed the drive to see if the problem was in the drive, and got the same result. The drive appears to operate correctly, but shifter still will not go into reverse... Any help wiuld be appreciated.
