New here and hoping there is someone that can help. Picked up a 1985 Barteeta I/O Mercruiser 140. This boat was stored inside for 25 years, was purchased new in 1985. Was done properly for storage, water drained, new oils, etc. Put in a new battery, muffs for water, oil is like new, new gas, etc. Turned her over, started immediately. Ran for about a minute or less, chugged along a bit and died. Tried to start again, fired but did not run, just turns over and does not fire at all. Removed the fuel line into the fuel pump, no fuel in the line I can see or barely smell. Took out the pump filter, not even wet. I am assuming there is not a kill switch I can find anywhere, I also assume this is only a mechanical fuel pump without any type of electric pump. As the boat has been sitting for 25 years, I am thinking that the fuel pump is the main problem? The person I got the boat from, did unhook the fuel tank line and used a gas can to feed fuel into the fuel pump. The engine ran like new for the time there was gas fed into the pump. I think possibly the reason it started for me for a minute was that there was still some fuel remaining in the pump or fuel line to the carb? And wondering if it would be best to try to locate the fuel pump or install an electric pump in its' place? I have attached 2 pictures of the pump. When I look for a replacement fuel pump, the pics I see show that mine is installed upside down, with the filter and bowl at the top of the pump? Is this correct?Any help is greatly appreciated. Thanks, Joe in St Charles IL.
