dusted_ya
- Mar 22, 2008
- 39
I have a 1970 Starcraft with a 120hp Mercruiser I/O that I've restored. When I first started the restoration a few years ago I hired a guy to replace the bellows and gimble bearing. Now it's restored and have had the boat out about 6 times and have started to notice water in the bilge area. The other day I opened up the engine cover and noticed water pouring into the boat. Upon inspection afterwards I noticed a tear in the drive shaft bellows about 2 o'clock. My buddy said he must not have replace the bellows and it started to tear with age. Since the boat is 48 years old there is NO ONE anywhere that will take it in for repair so I'm it for all repairs.
I removed the outdrive and gimble housing to start replacement and the bearing is got a definate rattle when I spin it by hand so it will need to be replaced. Also it appears that all the bellows were in good shape as if they had been replaced recently. The driveshaft bellows has two opposing flat spots on one end and they were installed at the 3:00 and 9:00 positions (is this correct?) Not sure what caused the tear other than possibly the inner ears of the gimble housing where the pivot pins are.
Was this tear a fluke? Was something installed improperly? I can not find anything on the internet showing proper installation. Also I need a transom seal kit but don't know which one I need for the pre-alpha model. SN: 2728089
Thanks for the help!
