bayliner09
- Aug 13, 2011
- 67
So here is what's going on I purchased a boat from a guy who said it hadn't run in a couple years it has A 3.7 L MerCruiser took it home found radiator fluid in the cylinder took the head off broke the Pistons free re-lapped The valves and reassembled the head on the motor after manual turning the crank to pump oil through the motor I put spark plugs in and proceeded to try to start the motor but the ground started smoking the motor just lopped not really turning over every once in a while it would pick up and spin a little bit faster but for the most part just loped and the ground smoked I'm just at a loss of what to do I hooked another ground to the battery and the motor in a different area and that one started to smoke instead of the first ground with both grounds attached at the same time what else could it be since the motor turns over with just a socket on a wrench it can't be seized
