Hey all! I'd like to get some info and options for this little project that I am starting.
The engine I have is a 4.3 Mercruiser. From the research that I have done, it seems to be a 1989-90 Buick. The CASTING # is 10105867. The research that this is pointing me to is a 1989-90 Buick block. I believe the block is cracked. I have it taken down to the crank, cam, and pistons. But in my inspection of the block, I found a fracture.
The first part of my question is, do you have anywhere that I can do more research on the casting number, or do you have knowledge weather I am correct on the year?
Part two, assuming that it is a 1989-90 Buick, would I simply be able to find a block at a salvage yard out of one of the cars that it was in? If not, is there a difference in the "marine" vs the "road" version if the cast numbers are matching?
Here is the PDF of some of the research that I have done. My casting number is the first one o the list if you are clicking on it. http://www.enginepartswarehouse.com/enginecatalog/GENERALMOTORS.PDF
Thank you in advance!
