rothfm
Ensign
- Sep 26, 2006
- 913
Experienced outboard person here, in beginning stages of assisting a friend that has a 2001 5.0 EFI MCruiser, fresh water cooled.
This season he is experiencing a rising heat/with RPM issue. I'm suggesting the steps for him to start with, listed below. Last season he did the mani's and risers as the history was unknown. Temps were fine last season after that work- steady at 160, all speeds.
The impeller was just removed and small areas of each vane was "eaten away" (small spots).
Currently Idle is about 170 in the water, with a 160 Stat...Upon planning off it climbs toward 200, and will lower again when backed off.
This setup has the Outdrive water path Blocking Plate in place, and uses a Thru-Hull intake with Belt driven water impeller.
Suggesting to him:
* Remove Exchanger for visual inspection, cleaning-looking for debris from last impeller
* Open Raw water side intake hose, and introduce water after the impeller, ensure good volume comes out the transom
* Open the coolant/antifreeze side, introducing water thru the block, ensure proper volume comes out.
* Remove and check any Power Steering, Cool-Fuel exchangers, if above flow-checks yield any flow restrictions
My big questions is THIS:
He has a "Hesitation" issue upon acceleration...If you hit the throttle it "bogs and hesitates" but will eventually catch up and run pretty smooth. If you accellerate lightly it does fine. I'm wondering if this "Bog/hesitation" issue can be related to the Heat-up problem? Meaning a vacuum leak also causing higher combustion temps, and bogging???
Is there a good way to test for bad head gasket/cracked head or block?
Suggesting to him:
