Hi, new member here, hope someone will have some advice for me. Bought boat last fall, they ran it for me before I bought it. Brought home, ran it, fogged engine,winterized motor etc. last month, tried starting, good cranking, no start, changed out points etc. to electronic, now starts, but idles rough and slow, then dies in 10-20 seconds. I'll change out to fresh fuel today and see what happens. I can't seem to find a way to give it some gas while starting. will only crank in neutral. I'm guessing its auto-choke, as there is no switch, and there's no throttle button on shifter to rev her up, in neutral, like in my manual has. Is it a timing problem, idle needs adjustment?, bad gas?, It came with 1/2 tank, which I stabilized before winter, any other ideas. oh yes, plugs, cap rotor, wires are very new, Tested coil, it's good. Also new fuel pump, filter. Any help would really help. Cheers.
