So some of you followed this and gave me some great advice. Chris gave some great advice and got me started on tuning my carb without wasting money on the Edlebrock tuning kit. I?m going to give a closing write up and make some statements that some will disagree with. I know that guy is going to say. You coulda had a V-8. Sure could have. But not even close to the 800 bucks I have in this little motor. So lets get started:
I did crack the intake and the block was in excellent shape. I have always had my suspicions that a 4.3 Mercruiser was a repackaged Chevy 4.3 from a S-10. I AM NOT discussing, distritributor, alternator, starter, starter solenoid. The block. I can see no evidence of anything other than a standard block. It does have a coating on the outside that has a striking resemblance to POR-15, a coating to inhibit corrosion. The casting plugs (freeze plugs) are brass. That is needed for saltwater. Your call on a fresh water boat. Crank, rods, pistons, valves, and springs appear to be the same. So what did I find different? Oil pan, intake, carb. The oil pan being different is a mystery. The intake needs to be different for salt water, and the carb needs to be different for the fast idle and most importantly the fuel drain in case of a stuck float. In my opinion you can ignore the marine price tag on a few things, but don?t cut corners on the carb. Venting fuel into the engine bay could cause a fire.
Lets talk cam. That great mystery stick that is shrouded in secrecy. I took the part number off my stock mercruiser and you guessed it. S-10. So I had a call with 2 cam companies. I ended up with Lunati. The tech knew my concerns and could discuss with confidence, reversion.
I ended up with a
1409 Edelbrock carb, with 95 main jet, 98 sec jet 068x.047 rod, with plain spring (8hg, .043 pump jet)
2114 Edelbrock intake
Lunati Cam .447in-.447ex lift at valve, 207in-207ex dur at .050, 266in-266ex advertised duration.
(not a big departure here from stock just more lift)
19p14dia Nemisis prop (gearing is 1.81 alpha one)
My goal here was 250HP. Will I know if I?m making that? No. Not gonna put it on a dyno. But here is what I do know. I had a 17 pitch prop and the motor would only hit 4800rpm if I were alone and light on fuel. First time in the water with the upgrades. Spun the 17 prop into the rev limiter quickly. With the 19p prop I can get above 4800rpm with 4 souls on board and ? tank. Yanked the skier out of the water and planed very quickly with excellent stern lift. Yes stern. The boat can plane and hold 17mph for wakeboarding now. That a good improvement from the 17p prop.
Testing numbers as follows:
Boat weighs 2750, 28 gal fuel, 450 gear/people
95 deg, 60% humidity, 600+- ftMSL
19p nemises:
3000rpm, 11invac, 22 mph, 26 prop slip)
3500rpm, 10invac, 29mph, 17 prop slip)
4000rpm, 8invac, 34mph, 14 prop slip (4000rpm, 10invac, 34mph, trimmed) trim didn?t make a difference in speeds below 4000rpm, as I trimmed I maintained 4000rpm and throttle was reduced to maintain rpm)
4500rpm, 5.5invac, 36mph, prop slip 20 (4500rpm, 8invac, 38mph, trimmed, prop slip 15)
4800rpm, 3invac, 39mph, prop slip 18 (4800rpm, 5.5invac, 41mph, trimmed, prop slip 14)
I had a 19p, banged up 3 blade prop that is my spare. It does not plane nearly as quickly as the 19p, 4 blade nemesis.
19p 3 blade:
3000rpm,22mph
3500rpm, 32mph, 8 prop slip, not trimmed
4000rpm, 36 mph, 9 prop slip, not trimmed
4500rpm, 38mph, 15 prop slip, not trimmed
4700rpm, 44mph, 6 prop slip, trimmed out
