After a long winter nap we took the boat out and have milk shake for oil in the 1996 4.3 with 2bl carb in a Bryant 192. I did a poor job winterizing and am now paying for it. I drained the water from the block before winter but didn't get good glycol circulation into the intake. I took the engine out and have started a tear down. Found 3 cracks in the intake and so far no other cracks. (think I got a little lucky) While I have the little Gerbil out I am looking at a better intake, a 4bl carb and would like to put a better cam in it. The only Cam I can find that specifies marine use is from Lunati. I am not looking for more top end, I am looking for a better hole shot with skiers. I am sticking with the 4.3 and not doing a V8 swap. So here are the questions and would like some opinions on:
1: How do I clean the oil/water and not do a complete teardown?
2: Any intakes beside Edelbrock?
3: Carb recommendations?
4: Cam recommendations with out going to hot and needing to fight hydro lock.
Thanks for your time on passing along some institutional knowledge!
