dlewis0714
- Mar 24, 2015
- 6
I have a 1993 Sea Ray with 4.3 Mercrusier. The boat has been running great all summer and the other day after I noticed the temp gauge got to about 180-190 after running it hard for 30 minutes straight so I drove around slow and it cooled right off. Next, I parked the boat went to get a bite to eat and came back got in boat and took off then it started to have power loss. I thought I got something in the fuel and I would check it after I got the boat out of the water. I got the boat out of water and took the plug and oil started coming out of stern. I investigated and noticed it looked like it was spraying out of dipstick and the top of motor. The motor is not making any funny noises and seems to be perfectly fine unless it's under load and gets to 3000 rpms and then smoke with oil starts pouring out of the breather tubes. I changed the oil and added marvel mystery oil and tried it again and still the same issue. There is no water in the oil and like I said with the muffs on I can rev 4500 RPMs and leave it there and its fine no blow by.
This boat sat for 10+ years and I replaced. Complete fuel system, all new ignition, starter, throttle cable, Rear main seal and crankshaft
