A little more progress on my issues. I got my injectors back from being cleaned/tested, they all checked out good and got about a 4% improvement across the board. This wasnt really the news i wanted to hear, i was hoping the #3 injector was bad. I reinstalled my injectors, made sure to put #3 injector into #7 cylinder to see if there might be a problem with the harness/pcm. Fired it up, still dumping fuel, but this time it was in the #7 cylinder. Good news, looks like it's a bad injector and not the pcm. Ordered a new injector and hopefully that will fix that issue.
As for the other problem, I hooked up the rinda scanner and looks like I'm having a emct issue. I'm going to replace the impeller and pull some of the water lines to see if there's any obstructions.
A question I have that maybe someone can help me out with... my wiring harness is labeled port on all the sensors/ plugs on the right side of the motor and starboard on the left. When I'm reading the scanner and it says "port emct overtemp" is that talking about the wiring harness orientation or the boats?
