I'm in the final stages of getting my new to me boat up and running and I'm now working on the trim which is the last thing I need before I can get back on the water. I just finished replacing the trim pucks which was a job and a half. I've got the sender hooked up and providing accurate readings. My only issue is when I hit any of the trim buttons nothing happens. I hear no clicking or anything coming from the unit. I was able to test the fuses and the pump is getting power on both sides of the fuses. The boat has been pretty well gutted but the wiring is still intact and just needs to be tied up, I feel there is a decent chance something just got unhooked but even after looking at the diagrams nothing seems off.
I'm not too sure what to test next the purple line from the throttle gets voltage when one of the buttons are (It's slipped my mind what one) pressed, however, the blue wire that plugs into the limit switch and y splits off does not when any of the buttons are pressed. I'm thinking it might be a ground somewhere that isn't attached but everything looks fine and nothing seems to be out of place. The trim unit is on a Mercruiser 165 unit and is a dual solenoid model. I do know the reservoir needs to be topped off but I feel I would hear some sort of noise out of the unit regardless.
