CaptainMak
- Apr 28, 2012
- 294
So I'm trying to diagnose a "slow acceleration" problem I'm having with my 5.0L EFI (TBI) Merc.
I pulled out the Mercury Distributor Ignition Sensor from under the CAP and attempted to test resistance between RED/WHITE and GREEN/WHITE wire connectors. OHM meter showing OPEN LINE. I know the manual states it has to be over 100 OHMs, so OPEN LINE would be defective ?
It's an open type sensor with all electronic components open to the elements. I even checked the 2 soldering points that the wires are soldered to. Still says OPEN.
The question is: Will the motor still run with this condition sensor? Because it starts up fine, but seems line it runs rich and slow to accelerate under heavy engine load. I also maxes out at about 3,000RPM. Or would I not be able to start the motor at all if this sensor was shot ?
