I'm doing some maintenance on my Alpha 1 Gen 2. I need to remove the shift cable to replace it; however, I cannot get the shift cable nut off so that I can remove the shift cable from the bell housing.
It is starting to strip, and I am not sure how to proceed. I noticed another user had a similar issue, but I did not want to resurrect that post to determine what their resolution was. Here is that post:
http://forums.iboats.com/forum/engi...tuck-won-t-unscrew-86-mercruiser-alpha1-gen-1
I've tried using a deep well 9/16" with a hammer drill, but as I stated above it is starting to round off. I've tried wd40, pb blaster, but nothing has helped. I'm going to try some Kroil Oil as well. I noticed in the above post they mention tapping and using an "easy out". I do not have a tap system, but I'd be willing to try an easy out if it works.
Can anyone confirm or offer me some suggestions? Thank you.
Jake
Jake
