enginesilo
- Jun 9, 2008
- 355
Went to remove the Alpha 1 Gen 2 shift cable nut that meets the bell housing and within 3 tries I stripped the bolt, was even using the special socket (Part #91-12037) to remove it, I can't win I tell ya.
What next? Should I go ahead and cut the shift cable from the backside of the bell housing and then figure out how to get the screw out the bell housing? Any tips appreciated.
Oil Reservoir Hose
What's the best way to remove this hose? From the backside of the bell housing? Should I replace this stretch of hose from the gimbal housing to the bell housing while I'm already in there doing my bellows?
Bondo achris AllDodge I'm guessing you guys have seen the stripped bolt before....I hope.
Oil Reservoir Hose
