The trim switch works when pressing down and nothing on up. I was going to remove the switch to see if I could clean it or maybe see if there was a bad wire connection. From a previous thread I found out how to remove the throttle, took off the lower locking screw and then removed the top screw near the switch. Thought I was there but after removing the top screw it looks like that was holding a bracket that in turn holds the switch in. However the bracket does not budge, like its welded in place, so the switch won't come out! I mean its in there, have tried prying on it some but it doesn't even move. Help please!
