998cc
- Mar 30, 2013
- 159
All. Is there a modern replacement hydraulic trim pump for the MC-1? I assume it is a Prestolite. The pump I have is shown in Volume II of the Mercruiser manual C-90-7107 in section 7A. I think my pump has a stuck pressure relief valve.
I have a second non-working pump that I took apart as a prep course for going through my boat pump. The inner valve body looks like a major box of tricks!
It looks like a replacement pump would be the best overall repair if one is available.
Boat is a 1972 Gulfstream with GM 250ci inline 6, 165 HP, MC-1 drive
Thank you.
Russ
Thank you.
Russ
